upgrade v9 to v10 - call failed - 403 forbidden
Discussion in '3CX Phone System - General' started by dbergsma, May 18, 2012.
  1. dbergsma
    Oct 27, 2008
    39
    Hi folks,
    I've upgraded from v9 to v10 running on w2008 server.
    Using snom320.
    Phones all register, dial from outstide to inside works fine, ivr fine, however cannot connect to extension.
    Internal cannot dial extension - receive 'forbidden' (below).
    window firewall turned off.
    any ideas?
    This was working on v9 for a long time. When upgrading, I did change machines, however kept same ip, etc.
    21:07:34.527 [CM503020]: Normal call termination. Reason: Forbidden
    21:07:34.526 [CM503016]: Call(10): Attempt to reach <sip:23@10.1.1.56:5060;user=phone> failed. Reason: Forbidden
    21:07:34.526 [CM503003]: Call(10): Call to sip:23@10.1.1.56:5060 has failed; Cause: 403 Use Proxy; from IP:10.1.1.65:2048
    21:07:34.461 [CM503025]: Call(10): Calling Ext:Ext.23@[Dev:sip:23@10.1.1.65:2048;line=35gj99t5]
    21:07:34.414 [CM503004]: Call(10): Route 1: Ext:Ext.23@[Dev:sip:23@10.1.1.65:2048;line=35gj99t5]
    21:07:34.411 [CM503001]: Call(10): Incoming call from Ext.21 to <sip:23@10.1.1.56:5060;user=phone>
    11,084
    325
    Why is there a Proxy involved?
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Snom phones generate this response in case if request is not coming from the server(or proxy) specified in the account configuration. How the phone verifies validity of the request is unknown. You need to search on Snom's "wiki" site and verify settings of the phone.
  4. paul.hadley
    paul.hadley New Member
    Aug 24, 2010
    122
    I have had a similar response from a Polycom IP 501. The answer in this case was to specify a RTP Port range in the sip settings. Is there a similar facility in Snom phones.
