Upgrade
Discussion in '3CX Phone System - General' started by Joe Archibald, Mar 22, 2018.
  1. Joe Archibald
    Mar 22, 2018
    I just upgraded from Elastix with Aastra scripts to 3CX.
    I have everything working. Got the provisioning going. All seems good.
    Then a user asked about Call Forwarding. I have a call forwarding menu item on the Aastra 57i, but it does nothing. I can't find a feature code in 3CX.
    any suggestions?
  2. jimbo59
    jimbo59 Member
    Nov 17, 2017
    357
    77
  3. Joe Archibald
    Mar 22, 2018
    That would be using the web interface / soft phone. Is there a way to do this from the Aastra phone?
    Like a * code or something
    thanks
  4. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,099
    166
    No way of changing call forwarding on phone, as above need to use webclient or 3CX client
    If the forward has to happen all the time, you can configure it within the 3CX console for that extension
