Server Log said:08:04:58.871 [CM501008]: *** Stopped Calls Controller thread ***
08:04:58.715 [EC000001]: Connection with configuration server is lost
08:04:58.699 Currently active calls [none]
08:04:57.763 [CM100001]: *!* Failed to initialize Call Manager *!*
08:04:57.763 [CM100001]: *!* Failed to initialize SIP Stack *!*
08:04:56.687 Failed to obtain short path name for [C:\ProgramData\3CX\Bin\Cert]
08:04:56.687 [CM101001]: Can not determine any local IP Address!
08:04:56.687 [CM501002]: Version: 10.0.19079.0
08:04:56.687 [CM501007]: *** Started Calls Controller thread ***
08:04:56.687 [CM501001]: Start 3CX PhoneSystem Call Manager
08:04:56.531 [EC200001]: Configuration server is connected: application:BACSERVER:5485/DBProvider local:127.0.0.1:49169 remote:127.0.0.1:5485
08:04:56.531 [CM501010]: License Info: Load Failed
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
