Upgraded from 12.5 to v14, some pages are 404
Discussion in '3CX Phone System - General' started by millsey, Jul 26, 2016.
  1. millsey
    millsey New Member
    Dec 21, 2011
    203
    Hi All
    We upgraded from v12.5 to v14 latest, last weekend. We are gettign 404 errors on the Services page:
    An exception occurred RestartServices Error: System.Net.WebException: The request failed with HTTP status 404: not found
    and
    Settings > Network > Port
    The request failed with HTTP status 404: Not Found.
    I don't want to reinstall! Is there any way to get past this please?
    Millsey
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,379
    84
    My advice would be to check that all services are running, and if yes, the check in C:\Program Files\3CX Phone System\Bin\nginx\logs\ which are the webserver logs that may point you in the right direction.
  3. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    IIS: Upgraded from 12.5 to v14, some pages are 404
    but that is location of v15 logs :S
  4. NickD_3CX
    Jun 2, 2014
    1,379
    84
    Oops :oops: :oops:
    If you are using IIS as the Web Server, check that the Application Pool and the Default Web Site exists and that it is started. Also if you have made any sort of modifications to IIS like redirections, best undo them for the time being.
