Solved Upgraded from PBX Edition to Standard but SIP Trunk Limit Reached
Discussion in '3CX Phone System - General' started by Brett Coleman, Jun 30, 2017.
  1. Brett Coleman
    Jun 20, 2017
    27
    Good morning All,
    I am running into an issue that (I think) should not be occurring.
    Yesterday, I used PBX Express to deploy 3CX onto the Google Cloud Engine and shortly thereafter paid for an upgrade to the Standard Annual version with 8SC.
    While trying to setup a 2nd SIP provider, I received this message:
    Here's a print from the license screen:
    Ideas on how to fix? Or perhaps a 'bug'?
  2. CentrexJ
    CentrexJ Member
    May 5, 2009
    458
    75
    Try restarting services
  3. Brett Coleman
    Jun 20, 2017
    27
    I rebooted the server no luck; I then tried restarting services...still not allowing more than 1 trunk.
  4. agp
    agp 3CX Team
    Aug 19, 2015
    151
    22
    Hi @Brett Coleman ,
    Navigate to Settings> License, click EDIT and then OK.
    Then clear your browser's cache and refresh the page.
    Let me know if that works for you.
    Brett Coleman likes this.
  5. Brett Coleman
    Jun 20, 2017
    27
    BINGO! It now allows more than 1 SIP Trunk.
    Thank you!
  6. agp
    agp 3CX Team
    Aug 19, 2015
    151
    22
    You are welcome :)
