upgraded to v10 and 3cx assitant?
Discussion in '3CX Phone System - General' started by equintana, May 25, 2011.
  1. equintana
    Dec 20, 2010
    57
    I upgraded from 9 to 10. Fine fine... without problems.
    But, every 3cx assistant have been disconnected...and impossible to reconnect.
    Must be removed that software? upgraded? or what?
    regards
  2. JonasNielsen
    May 25, 2011
    3CX Assistant is not compatible with v10 as far as i know.
    You should uninstall it and install MyPhone instead
  3. equintana
    Dec 20, 2010
    57
    OK... then first remove 3cx assistan?
  4. JonasNielsen
    May 25, 2011
    Yes
  5. equintana
    Dec 20, 2010
    57
    Removed... where to download the web program again?
    Regards
  6. axion1
    Nov 18, 2009
    10
  7. equintana
    Dec 20, 2010
    57
    HI,
    When I logon using my high level privilege user, I can install /myphone without problems, but problems with less privileges.
    The can logon at ip:5000/myphone using extension and pin but, not shown the option to install the software.
    any idea?
    regards
  8. gabrielme
    Mar 31, 2010
    Yes, the install button (small and dificult to see) is in the Right corner of the web page, close to Help incon and Logout link. (we are talking of 3CX MyPhone web portal, and not 3CX Phone) *Please note and compare the old version of 3CX MyPhone in the old YouTube video and this new version of 3CX MyPhone the link is remplace by a icon.
    Next you see a new window (the same 3CX MyPhone program) and go to: Settings tap (The blue wrench incon) > Preferences, and click INSTALL. Now you can see another new window with the .EXE setup file for install.
    *Remember, to access to your 3CX MyPhone web portal (first step) yo need to go to your web browser and type: http://XXX.XXX.XXX.XXX:5000/MyPhone (reemplace X for your 3CX server IP, for example: 192.168.1.1)
    Sorry I dont´t remember more details, was very confuse and difficult to find all installation steps in one page. :S
  9. equintana
    Dec 20, 2010
    57
    HI,
    That install button is not shown when running ie with an user with no privileges
  10. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Naturally since the user has no installation permissions available.
