salter said:I forgot 8. - check your templates (again, if you had customized them to begin with) and re-apply any changes. I don't recommend just copying your old templates over as the 3cx staff does make GOOD changes - but you may need to "merge" your changes with theirs. - Then restart the 3cx services to reload the modified templates.
SY said:Each time when I read about "restart 3cx services" I 'm getting angry... :mrgreen:
SY said:99.9% of changes doesn't require restart.
the rest is - direct changes in database using third party tool, changing of logging level and changing of stratup options (.ini files)
Are you sure that the restart of 3cx services is required in case if changes are made for templates?
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
