Upgrading firmware for a lot Cisco SPA50X with provisioning
Discussion in '3CX Phone System - General' started by pbechta, Sep 15, 2010.
  1. pbechta
    Dec 23, 2009
    I would like to upgrade the firmware for a lot of Cisco Phones (SPA50X) in v 7.4.6 .
    The only way I see is to modify and use the Cisco template provisioning.
    I didn't find anywhere an information notifying the field name that could do that.
    Has anyone ever done that before ?
    Best regards.
  2. GraniteGuy
    Sep 15, 2010
    Have you checked on the Provisioning tab and the field name is Profile Rule - or at least that's what I use on other models of Cisco VoIP equipment.
