Upgrading from v11 to v12
Discussion in '3CX Phone System - General' started by brianoakes, Oct 27, 2013.
  1. brianoakes
    May 12, 2012
    92
    Howdy!
    We are current in our upgrade insurance through April 2014. What is the process to upgrade to v12. Is there a cost?
    I assume it's just a backup and then an install, and the settings will migrate. Can I just download the trial, and will my key work?
    Thanks!
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    803
    45
    Hi Brian,
    There are no costs involved to upgrade your Phone System.
    As you can read in the release notes of v12 SP2 (http://www.3cx.com/blog/releases/3cx-phone-system-12-service-pack-2/)
    "Backup your 3CX Phone System, uninstall your current version and download and install the latest version. Once the installation has finished, restore your backup."
    And: "3CXPhone System version 11 users can remove 3CX MyPhone, Desktop Components and Silverlight using this tool http://downloads.3cx.com/downloads/3CXV11MyPhoneCleanupTool.msi"
  3. brianoakes
    May 12, 2012
    92
    Thanks for the info! I will do some testing and get working toward the update. Thanks!
