Upgrading from V11 to V15
Discussion in '3CX Phone System - General' started by Richard waldron, Mar 16, 2018.
  1. Richard waldron
    Mar 16, 2018
    I am looking for download links to get some older versions of 3CX
    We have been using an old V11 and recently got a virus which corrupted most files
    I have installed the original V11 and taken a fresh backup from the original
    This has worked but didn’t import the licence and won’t connect to the browser to check the licence or updates
    I have updated our licence to a V15 annual
    Licence which I have been going to do for some time
    Now i just need to restore from the old V11 backup
    I believe i will need upgrade the original starting with V11 service pack 4 upwards
    Richie
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,303
    249
    #2 craigreilly, Mar 16, 2018
  3. Richard waldron
    Mar 16, 2018
    Thanks Craig,
    Unfortunately V12 wont accept the backup from V11
    The 3CX upgrade document suggests the following
    • From v9 and v10 you must upgrade to v11 SP 4a first, then to v12 SP 6.1
    • From v12 SP 6.1 you must go to v12.5 first. *
    • From v12.5 SP2 you can go to 15(.5) *
    • From v14 SP3 you can go to v15(.5) directly.
    It looks live I may need V11 SP4a first
    Richie.
  4. CentrexJ
    CentrexJ Member
    May 5, 2009
    432
    67
    I'll check and see if I have a copy of the v11 with SP4a for you.
  5. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,095
    165
  6. complex1
    complex1 Active Member
    Jan 25, 2010
    788
    45
