Upgrading from v14 lost presence
Discussion in 'Windows' started by thinking, Nov 8, 2016.
  1. thinking
    Aug 20, 2013
    8
    Upgrade from v14 to v15 went quite smoothly but after installing the new Windows 3CX client we don't have any presence on LAN or remote 3CX clients.
    No changes were made to the firewall.
    10,861
    301
    Did you re-provision the devices?
    Does the 3CX Firewall test pass?
  3. thinking
    Aug 20, 2013
    8
    Yes I've resent email and redone client config.
    The remote client never had 3CX before so was a clean setup.
    Something in provisioning must be screwed up, think Ill try a reinstall.
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,407
    458
    Make sure that no antivirus software is installed on the server and windows firewall is off. For remote extensions make sure that port 5001 is open on the firewall.
  5. thinking
    Aug 20, 2013
    8
    I have now reinstalled, only thing different this time was I used the 3CX provided FQDN both for internal as well as public.
    Clients internally still get no presence or contacts, external as well.
    What port do clients use for presence? I want to check your Nginx config.
  6. thinking
    Aug 20, 2013
    8
    Resolved :)
    Despite having every 3CX path excluded in BitDefender including disabling the firewall module and Windows firewall - uninstalling BitDefender resolved the issue.
    Thx.
