upgrading from v6 to v7
Discussion in '3CX Phone System - General' started by jeremyn, Jan 24, 2009.
  1. jeremyn
    Mar 25, 2008
    42
    hi all,
    woulding if there are any known issues which should be taken into account when upgrading from v6 to v7 ?
    do you need to be on the latest version of v6 to do an upgrade ?
    are there any step by step guides ?
    I saw one thing about needing to recreate extentions is this still the case?
    thanks
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    You should be at 6.1 and all working as expected. Then make a backup, uninstall V6, install V7 and restore your backup.
    Its a 10 minute job.
    NB..If you need your call records, ensure you import them as per FAQ before you go to V7.
