Upgrading from v9
Discussion in '3CX Phone System - General' started by ChrisPriest, Jul 15, 2011.
  1. ChrisPriest
    Feb 17, 2010
    20
    Hi All,
    Just a quick one, if we upgrade to v10, will the assistants automatically upgrade to the Silverlight version?
    Best Regards
    Chris
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    No they won't, you need to uninstall the assistant, uninstall V9 (do a backup of course) and install fresh V10.
    Thanks,
    Nate
  3. willow
    willow Member
    Mar 1, 2011
    471
    the assistant and the myphone app are 2 different things. The assistant will fail to connect and you be forced to download the assistant if you want or you can use the webpage. i do beleive that that you will also need to re setup any outlook intergration you are using as it is a different product.
