Upgrading the FXO gateway
Discussion in '3CX Phone System - General' started by beaver, Feb 24, 2009.
  1. beaver
    Aug 2, 2007
    30
    We have been using a grandestream gxw4108, it works fine but when it comes to big trafic with the 3cx, the quality of some calls deteriorate. We think is time to upgrade the gateway, what will be a good option? Talking about price and quality.
  2. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    We use Patton and never have any problems with them - they just work.
