Upgrading to v12
Discussion in '3CX Phone System - General' started by danturk, Nov 23, 2013.
  1. danturk
    Oct 21, 2011
    I currently have a system running v11. When I bought the system my grandstream phones and Sangoma card were supported. Now I look at the supported list for v12 neither are listed. Should I upgrade? Or will it not work as well?
    System 3cx v11 pack 4
    Sangoma a101 pri gateway card with netboarder express software
    Grandstream GXP2100
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    We use almost nothing but Grandstream handsets nd have had no issues when upgrading to v12, though I have no experience with Sangoma cards and cannot give you an answer based on experience when it comes to Sangoma cards. With that being said I'di back it up and restore using v12 and give it a test whirl if worse comes to worse you can always go back to V11
  3. bardissi
    bardissi Member
    Jan 31, 2012
    318
    I would drop the Sangoma cards... not worth the headache.
    The Grandstream phones will work despite the marketing spit between 3CX and Grandstream.
    We has deployed a bunch of GXP2124's over the last 60 days with no issues.
  4. 12494
    12494 Member
    Apr 16, 2010
    291
    25
    Ditton on drop the Sangoma.
    Recommend Patton as replacement.
    Regards,
    Allen
