Upgrading to v15 + extensions amount
Discussion in '3CX Phone System - General' started by daktur, Feb 18, 2017.
  1. daktur
    daktur New Member
    Oct 15, 2015
    226
    7
    Hi all,
    I will upgrade my v14 sp3 to v15 due of this tunnel issue that is causing my clients a lot of instability.
    While installing the new version, I want to upgrade the extensions from 999 to the maximum amount possible.
    Does anyone knows how the system will handle this upgrade when I restore backup?
    Thanks in advance for your help!
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,079
    202
    You would have to export the extension list, create a new PBX. Select 5 digits.
    Update the Export with the new extensions, and import it.
    The issue will be the loss of Voicemails and recordings.
    AFAIK, 3cx has no supported mechanism to change from 3 to 4 or 5 digit extensions or downgrade to 2 digit extensions.
  3. daktur
    daktur New Member
    Oct 15, 2015
    226
    7
    I have just updated and actually when restoring and existing backup it does not let you change the extensions length.
    I hope they enable this change online without reinstalling soon.
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,425
    352
    As of now there is no such functionality. To change the extension length you need to install from scratch and follow the procedure that craigreilly mentioned above for your extensions.
  5. craigreilly
    Feb 1, 2012
    3,079
    202
    That is exactly what I said. The option was to EXPORT the extension list and import it on a fresh install.
