Upgrading very old version (12)
Discussion in '3CX Phone System - General' started by pjohnson@keepusrunning.com, Dec 29, 2017.
  1. pjohnson@keepusrunning.com
    Nov 30, 2015
    I have a client on v12.0.41311.996 SP6.2. They are finally wanting to upgrade. Maintenance has been in place the whole time, so they are covered there.
    I was wondering what the steps would be? Looks like 12.x to 14 was backup, uninstall, reinstall, then restore. Then to 15 was the same. Could I just jump from 12 to 15.5? I will probably take a full backup first and then do this on a new disk so I can go back if necessary.
    Thanks in advance.
  2. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,218
    174
    No you cannot jump like this, you will need to go up incrementally. I think a jump from 14 to 15.5 should be OK but you will need to test this out for yourself.
    Also bear in mind that in older versions of 3CX you had to use the backup and restore module.
    Below are your installer files:
    https://downloads.3cx.com/downloads/3CXPhoneSystem125.exe
    https://downloads.3cx.com/downloads/3CXPhoneSystem14.exe
    https://downloads.3cx.com/downloads/3CXPhoneSystem15.exe
    https://downloads.3cx.com/downloads/3CXPhoneSystem155.exe
  3. leejor
    10,731
    277
  4. pjohnson@keepusrunning.com
    Nov 30, 2015
    Thanks for the replies. I will tackle this soon!
  5. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    #5 sip.bg, Dec 30, 2017
  6. apostolis_3CX
    apostolis_3CX Support Team
    Nov 1, 2017
    149
    15
    To upgrade from a previous version of 3CX:
    Make a backup of your current configuration using the 3CX Backup and restore tool.
    Tick the options to include in your backup, then choose where to save your backup. Warning: Do not choose to store the backup inside any of the 3CX Phone System installation folders as these folders are removed during the uninstall process.
    Uninstall the current version from the “Windows Control Panel > Programs and Features”.
    Now download the 3CX Phone System v15 of choice.
    Proceed with the installation.
    Restore your configuration when prompted.
    Notes:
    From v12 SP 6.1 you must go to v12.5 first. *
    From v12.5 SP2 you can go to 15(.5) *
    From v14 you can go to v15(.5) directly.
    Backups from previous versions can only be restored during the installation of the pbx.
