Upload Custom Logo Yealink
Discussion in '3CX Phone System - General' started by Heath, Oct 18, 2017.
  1. Heath
    Heath New Member
    Aug 12, 2017
    107
    I have Yealink 1 T26 & 3 T28 and need assistance with 2 items. On all of my phones I have BLF on the program keys. Now on all but 1 T28 The BLF keys are green when the extension is idle and Red when the extension is in use. On 1 the BLF keys are not lit up when the extension is in idle and the key lights up red when the extension is in use. I want to get my other 3 phones where the keys do not lit up when the extension is in idle, but how do I do that.. Lastly, I have my custom label in DOB format. How I get my logo on the provisioning server. Everytime any of the phones need to be re-booted, I have to go back into the webGui and re-upload it on all the phones.
  2. Philip Darnell
    Philip Darnell New Member
    Jan 26, 2017
    132
    10
    To change the logo to your own you'd have to create a custom Template and edit the background image. So you would edit the following line:
    phone_setting.backgrounds = Config:yealinkt28.dob
    and change 'yealinkt28.dob' to your file name. Make sure your logo is saved in the following folder C:\ProgramData\3CX\Instance1\Data\Http\Interface\provisioning\sh28n5uidot\logo
  3. Dave-TTG
    May 15, 2017
    25
    8
    You can also just name your custom logo the same as the standard 3CX one, then replace the file on the PBX - This achieves the same end goal without having to resort to custom templates :)
    NickD_3CX and Philip Darnell like this.
  4. Philip Darnell
    Jan 26, 2017
    132
    10
    Yeah, your way is better :) ha
