Upload Voicemail Prompts
Discussion in '3CX Phone System - General' started by marcd, Jun 30, 2009.
  1. marcd
    Jun 30, 2009
    I have some professionally recorded voicemail prompts for general mailboxes. Is there a way for me to upload these? I really don't want to use the handset... Thanks!
  2. matictec
    matictec New Member
    Mar 31, 2008
    188
    create a personal prompt in the voicemenu of the extension and than you can replace the personal prompt with your prompt.
  3. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,557
    118
    You can go in your: C:\ProgramData\3CX\Data\Ivr\Prompts\Sets\8210986B-9412-497f-AD77-3A554F4A9BDB folder and replace the appropriate prompts.
    Afterwards give IISadmin / Phonesystem a Restart just to be sure. To do this go to Start > Run > services.msc and find the services i mentioned.
  4. arkitekt
    Jul 6, 2009
    14
    Hi LeonidasG,
    I don't seem to have that Prompts folder you mentioned -- is it possible this could be different for some installs? I'm on Windows XP with the program installed on the D: drive --- I found the IVR folder but no Prompts folder inside.
    I'd really like to upload the voice prompt for the extensions as well, this would be a great feature improvement.
  5. ec268
    Apr 18, 2009
    22
    Please firstly record once by using phone set. You will get the folder then.
  6. LeonidasG
    Nov 19, 2008
    1,557
    118
    C:\ProgramData\3CX\Data\Ivr\Prompts\Sets\8210986B-9412-497f-AD77-3A554F4A9BDB for Vista / 2008 Users
    C:\DocumentsAndSettings\All Users\3CX\Data\Ivr\Prompts\Sets\8210986B-9412-497f-AD77-3A554F4A9BDB
    Or else if you are using something older than V7, check in: C:\Program Files\3CX\Data\Ivr\Prompts\Sets\8210986B-9412-497f-AD77-3A554F4A9BDB
    One of these paths must be correct.
    Go in these Folders and Replace the Dafault Prompts with the ones you have.
  7. arkitekt
    Jul 6, 2009
    14
    Thanks! I found them and this information did hold the correct info.
