Urgent assistance needed with remote pots location
Discussion in 'Windows' started by jeff yager, May 6, 2015.
  1. jeff yager
    Oct 10, 2012
    17
    Hello, I have a 7 venue 3cx for windows system. I am installing a new location that has DSL only and cannot do voip there. I need to pull in century link pots phone system and link to my 3cx system. I have no clue how to do this. Has anyone out there done this before? Can any one provide some assistance?
    Thank you,
    Jeff Yager
    10,573
    247
    Whether Century link providers either an FXS "box", or simply a copper cable termination, you will need a VoIP gateway. There are a number that are supported by 3CX. These are usually available in multiples of four lines.
    http://www.3cx.com/voip-gateways/
  3. jeff yager
    Oct 10, 2012
    17
    Yes, I am aware, I have used them for fax before.
    Problems are this:
    call comes into 3cx server, then routes out to pots line. Does the FXS go where century link terminates then out to phones? If so then I can control everything via extension as I would with a voip setup.
    Or would I need multiple pots lines? I plan on having approx 10 phones at this location.
  4. leejor
    10,573
    247
    I'm not entirely clear on the set-up. Is the 3CX server located at the same location as the sets, and where Century link will terminate?
  5. jeff yager
    Oct 10, 2012
    17
    No it is not. It is at another office.
  6. leejor
    10,573
    247
    If the gateway is not located at the same location as the server, then (as came up in a previous post), your only option may be to set-up a VPN connection between the two locations. Everything will appear to be on the same network. Bandwidth may be a consideration.
    I guess you couldn't get Century Link to terminate at the server location.
