Urgent help :Login problem after Power loss
amygoda
I can’t access to the server
After power loss the login server say’s Invalid password or name. Try again.
Hello all
any hope or I should reinsall 3CX
Hello Matt,
thanks for reply
I read both posts and did search the posts
I did every thing and restart seeral times
I still can't access to the server
Hello Matt
nothing helps in this post
Hello Matt,
I can't access to 3cx system to backup?
how could I do backup without login?
hello Matt,
I do have an old backup
But ysterday I did a lot of new configurations to test remot phones to post answers in 3cx forums
I need to contenu the test
I'll install 3cx again
Thanks a lot
Hello Matt,
thanks for tip
my tip I used to use symantec ghost from dos
but it take The image manualy
you said backupexec can move windows system from pc to another
when I do this by ghost From pc to another pc (both pc are twin specification)
the new take too much time on windows start screen Then works normaly
also when i take an image from p ata harddisk to sata harddisk it does not work at all
Getting Started - Admin
cc92260
Get 3CX - Absolutely Free!
3CX
