URGENT NEED HELP, phone sytem got struct by lighting
Discussion in '3CX Phone System - General' started by 3397premier, May 25, 2012.
  1. 3397premier
    Apr 2, 2012
    43
    Our phone system got struct by lighting yesterday. Now we have lot of phone problem like: 1 or 2 way no audio, hear static on the phone. I don't know where to start to troubleshoot the issue. So far we called Comcast to replace the modem because the speed just went up and down in huge gap. We are trying to troubleshoot the phone problem right now. Any suggestion really appreciate, thanks for your help
    Our equipments
    7 switches
    1 router (asa 5505)
    Comcast internet modem (use for VOIP)
    3cx server (Dell R510 with window 2008 64bits r2)
  2. gschwab
    gschwab New Member
    Mar 21, 2012
    131
    I would begin by disconnecting all the phones
    Check your server make sure all services are running
    run firewall checker
    re connect phones one at a time
    same with switches
    Good luck
  3. charris
    Mar 26, 2012
    I am not sure there is much you can do. Even the components that look ok might develop problems soon or later. The best is to push for the insurance to change everything - hoping the system is included in the insurance.
  4. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    I would start by uploading your backup files to a machine operating correctly for an immediate work around until you get your server operational or replaced.
  5. leejor
    10,754
    286
    Use a known "good" (one that wasn't plugged in at the time of the strike) phone, for any trouble shooting .
    Backup and replace the server. Work out from there adding pieces of equipment one at a time.
    You can even restore to a PC/laptop, for testing purposes.
    Even running the "free" edition will allow you to test the phones and switches for problems.
    If you don't already have one, go out an buy a good quality UPS and add surge/lightning protectors through out the network/LAN as much as practical.
    If you live in an area where lightning strikes occur, and it appears you do, it is worth the extra cost for protection.
