Urgent Problem
Discussion in '3CX Phone System - General' started by Anonymous, Dec 1, 2006.
  1. Anonymous
    Anonymous Guest
    i have several SIP accounts with several providers.. Inphonex.. CallCentric.. Stanaphone.. Broadvoice,
    i tried to set up all of them .. still i'm unable to recieve calls nor make calls.. all i could do is to call the extentions..
    i did the outbound rule but still no use..
    20:23:15.484 Terminated c20 "100"<sip:100@192.168.1.2> <sip:03476324101@192.168.1.2> Call ended
    20:21:16.218 Calling c20 "100"<sip:100@192.168.1.2> <sip:03476324101@192.168.1.2> Send INVITE to [#2867807 @Inphonex]
    20:21:15.296 Routed c20 "100"<sip:100@192.168.1.2> <sip:03476324101@192.168.1.2> From: Ext:100; To: [#2867807 @Inphonex]
    20:21:15.296 CallConf::findDestination: Found destination [#2867807 @Inphonex] for caller Ext:100
    20:21:15.250 Registrar::checkAor: Registrar resolved sip:100@192.168.1.2 as <sip:100@192.168.1.9:5060>
    when ever the call is made.. it rings but nothing happens.. i even called my voice mail.. and it RANG!!!!!!
    can anyone help with this matter??
  2. Anonymous
    Anonymous Guest
    same error
    i am getting the same error with Vonage:
    21:17:24.640 Terminated c69 "NICK V"<sip:100@192.168.0.104> "12142575555"<sip:12142575555@192.168.0.104> Call ended
    21:17:17.250 Calling c69 "NICK V"<sip:100@192.168.0.104> "12142575555"<sip:12142575555@192.168.0.104> Send INVITE to [#12142575555 @Vonage]
    21:17:11.093 Routed c69 "NICK V"<sip:100@192.168.0.104> "12142575555"<sip:12142575555@192.168.0.104> From: Ext:100; To: [#12142575555 @Vonage]
    21:17:11.093 CallConf::findDestination: Found destination [#12142575555 @Vonage] for caller Ext:100
    21:17:11.062 Registrar::checkAor: Registrar resolved sip:100@192.168.0.104 as <sip:100@192.168.0.104:14050;rinstance=a9b325df45dda859>
    21:17:11.046 Incoming c69 "NICK V"<sip:100@192.168.0.104> "121425755556"<sip:1214255555@192.168.0.104> Incoming call from 100
    21:16:24.453 Terminated c68 "NICK V"<sip:100@192.168.0.104> "12398215555"<sip:12398215555@192.168.0.104> Call ended
    21:16:23.312 Calling c68 "NICK V"<sip:100@192.168.0.104> "12398215555"<sip:12398215555@192.168.0.104> Send INVITE to [#12142575555 @Vonage]
    21:16:17.140 Routed c68 "NICK V"<sip:100@192.168.0.104> "12398215555"<sip:12398215555@192.168.0.104> From: Ext:100; To: [#1214255555 @Vonage]
    21:16:17.140 CallConf::findDestination: Found destination [#12142575555 @Vonage] for caller Ext:100
    21:16:17.109 Registrar::checkAor: Registrar resolved sip:100@192.168.0.104 as <sip:100@192.168.0.104:14050;rinstance=a9b325df45dda859>
    any suggestions anyone?
    I am running the latest version 2.0.895.0
  3. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Re: same error
    Yes, we're aware of this problem in the latest build. For details, please, read announcement regarding problems in v2.0.893.0
    Best regards,
