Url forward feature exist ?
Discussion in '3CX Phone System - General' started by abt, Jul 22, 2010.
  1. abt
    abt
    Jul 22, 2010
    Dose he exist a feature to open an url with the number of the caller ?
    Thanks you
  2. carolinainnovative
    May 4, 2009
    369
    6
    If you mean through the assistant in a "call pop" type manner, you could easily launch internet explorer through the "notify external program on incoming call" feature.
  3. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Yes you can send the ID to the browser in whatever method you wish. First you need to have the 3CX assistant installed and the use the notify external program and in the adress that you want to call for example
    http://www.whitepages.com/search/ReversePhone?full_phone=44455556666 - please note
    Would become
    http://www.whitepages.com/search/ReversePhone?full_phone=%callid%
    That will tell internet explorer to launch this link and the assistant will change the callid with the actuall callers ID.
