US VOIP provider , freedigits configuration problem
Discussion in '3CX Phone System - General' started by jetronic, Jul 22, 2007.
  1. jetronic
    Jul 22, 2007
    11
    Any body help me with freedigits voip configuration for 3CX?
    Basically I have a US telephone number provided by freedigits. And I've run a 3cx PBX and soft phone in my computer. but I found the line cannot be registered by 3CX soft ware PBX.
    here's my configuration:
    Registrar/Proxy Hostname or IP :freedigits.net
    Registrar/Proxy Port : 5060
    Outbound Proxy Hostname or IP :freedigits.net
    Outbound Proxy Port (default is 5060) :5060
    STUN server Hostname or IP: (empty here)
    STUN server Port (default is 3478) :3478
    Is it right?
    VOIP line is a US number: so I put 001 as a prefix
    0016412******
    anybody help me out!
    or 3CX simply couldn't support it?
    I live in Shanghai, China with ADSL environment
  2. jsilvey8
    Jul 12, 2007
    leave out the 011 you are not dialing an international number. it acts as a local us number. I have it on my system works fine.
    Jim
  3. agwilshire
    Sep 19, 2007
    free digits config
    How Do I Configure free digits To Work With 3cx
    Thanks Adam
  4. pcrazz
    Oct 28, 2007
    Config?
    Ok. I am getting registration errors. I have freedigits free version. How do I setup user and pass stuff? Thanks. Please help me. I have been trying for about 8 hours now.
    Sam H.
