USA SIP trunk with unlimited channels ?
Discussion in '3CX Phone System - General' started by Fatboy40, Jun 13, 2011.
  1. Fatboy40
    Fatboy40 New Member
    Aug 2, 2010
    170
    Is anyone aware of a SIP trunk provider in the USA that provides a package with unlimited channels ?.
    I've used these guys in the UK...
    http://www.voip-unlimited.net
    ... who have an excellant service, with their trunks providing unlimited channels, but I can't find anything similar in the USA.
    Thanks.
  2. willow
    willow Member
    Mar 1, 2011
    471
    voip.ms will give you 25 channels per number.
  3. Fatboy40
    Fatboy40 New Member
    Aug 2, 2010
    170
    The 'Metered Usage' plan from nexVortex seems to be the closest to what I need, however, it would be nice if the outbound call costs were a little smaller than 2.5 cents a minute.
  4. willow
    willow Member
    Mar 1, 2011
    471
    most companies that uas a metered usage will give you unlimited calls coming in. those that offer the no LD,local charges usually are priced by a concurrent call.
  5. lightshade
    Jan 7, 2013
    I'd try sipforcallcenters.com they offer the lowest cost sip trunks and they are based on USA.
  6. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    We always and only offer unlimited channels, you pay per use (per minute). Tier 1 direct peering only, owned facilities (not "co-locating" or using shared, VPS or someone else's junk servers). You can call me if interested.
  7. garrettsmith
    Sep 7, 2015
    You should checkout SIPTRUNK.com (http://www.siptrunk.com). They offer $20 Unlimited SIP trunks (US48 & Canada). They're 3CX Certified and offer 3CX partners 20% commissions. Also you get a free sip trunk to test out.
