USB handset with windows client
Discussion in 'Windows' started by 2way, Mar 5, 2015.
  1. 2way
    Jan 8, 2015
    For those wanting a more traditional telephone, is it possible to use a USB handset with the windows client?
  2. positron
    Jan 14, 2013
    76
    11
    Any audio device recognized by Windows will work in the basic sense.
    I have recently done some preliminary testing with the Jabra Dial 550 and the Plantronics Calisto 240, both USB handsets with keypads and displays. With the appropriate Jabra and Plantronics software, they support answer, hangup and mute functions as well as some caller ID info on the display for incoming calls. However, the built-in keypad does not function for dialing on either handset.
  3. troosters
    May 8, 2014
    17
    is there a usb handset in the meantime that fully works ?
