USB Long Range Wireless Head Set
Discussion in 'Windows' started by maharshi_raval, Sep 3, 2014.
  1. maharshi_raval
    Sep 3, 2014
    7
    Hi Everyone,
    I am new 3CX but so far have managed to do a fresh install and get everything working. But now as we are using most of our Extensions with Softphones. Is there a recommended Headset to be used with Windows Desktop Phone App.
    The features I am after is :
    1. Wireless
    2. Long Range (this rules out the Bluetooth headsets)
    3. Ability to Pick up and End call thru Head Set Button.
    Kind Regards
  2. AndreasA_3cx
    Jun 2, 2014
    19
    Hello there and thank you for contacting us.
    Unfortunately we are not recommending any hardware, the choice of what hardware you will use it is entirely up to you.
    You can see the list of the supported hardware in the following link: http://www.3cx.com/support/
    Kind Regards
  3. maharshi_raval
    Sep 3, 2014
    7
    Thanks for the reply AndreasA_3cx. Appreciate your time. sorry did not realise that it was much obviously stated on the support page.
    Kind Regards
