Use 3CX softphone on a panasonic pbx
Discussion in '3CX Phone System - General' started by maisiba, Dec 31, 2014.
  1. maisiba
    Dec 31, 2014
    I have a Panasonic PBX KX-NS500 with a local Airtel E1 line (Airtel-Kenya)
    Can i use 3CX Softphone on the PBX to allocate extensions for my office users.
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    The answer is strong maybe. If the system supports SIP 2.0 and you are speaking of the 3CXPhone6 softphone application and not the 3CXPhoneforWIndows12 which is only usable with the 3CX platform, then you can likely use it. However, the 3CXPhone6 application does not support all the features that your PBX may provide such as presence. There may be others as well.
    As the software is a free download, you could always try it and see.
