No, it's not possible, because Voip Client doesn't have implemented the communication interface required by Assistant.bluetel2 said:it's possible to use 3cx voip client 7.0 beta with 3cx assistant v8 to replace 3cx voip phone?
To be honest, I don't know :roll: Well, but what's happen in case you won't like the new skin also? Do you have a graphic designer there?bluetel2 said::cry:
tks Vali.do you know when new skin will ne release ?
Vali_3CX said:To be honest, I don't know :roll: Well, but what's happen in case you won't like the new skin also? Do you have a graphic designer there?bluetel2 said::cry:
Skin generator is not available yet for "public use" but, since we already announced that skinning will be available, I will start to make a document about how to create a skin. Briefly, you will have to create one .ini file and several bitmaps. We cannot release right now the skin generator, because its "protocol" (or API, if you like) is not well established, and it still has some "IPhone-like" dependencies to be removed, but once you have these files, you may send them to us and we will create the skin and send it back to you.bluetel2 said:I can make my own skin for VOIP phone ?
Vali_3CX said:Skin generator is not available yet for "public use" but, since we already announced that skinning will be available, I will start to make a document about how to create a skin. Briefly, you will have to create one .ini file and several bitmaps. We cannot release right now the skin generator, because its "protocol" (or API, if you like) is not well established, and it still has some "IPhone-like" dependencies to be removed, but once you have these files, you may send them to us and we will create the skin and send it back to you.bluetel2 said:I can make my own skin for VOIP phone ?
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
