I doubt that it can be done without "deep" update of the OS installed on your phone...dgedge said:hello everybody,
do you know if there is a way to use an android phone as gsm gateway in 3CX phone system ?
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
