Use built-in earpiece instead of Bluetooth headset
Discussion in 'iOS' started by breyed, Dec 3, 2012.
  1. breyed
    Dec 3, 2012
    In the standard iPhone phone app, when a Bluetooth headset is connected, you can select during a call between the speaker, the built-in earpiece, and the Bluetooth headset. It seems that with 3CXPhone, you can only choose between speaker and Bluetooth headset. Is that right, or is there a way to select the built-in earpiece?
  2. StefanW
    Jun 2, 2009
    1,199
    79
    right, only the GSM of iphone can do you.
    From an app the iOS tells us only 2 device are avaiable now.
    So you must use the BT when present, we can not change it
  3. breyed
    Dec 3, 2012
    Thats too bad, but thanks for the response. You might want to post a question to stackoverflow with a snippet of the code your using to get the audio path selections, in case someone knows of a workaround for the limitation.
  4. StefanW
    Jun 2, 2009
    1,199
    79
    BT for 3rd Party Application is managed by iOS very badly.
    Even CallPickup is not working... so you know where we are @ v :lol:
