Use gateway in other server
Discussion in '3CX Phone System - General' started by MasterX, Sep 22, 2010.
  1. MasterX
    Oct 2, 2008
    28
    I have a server with 3cx system ; this server already in use haven't device audio.
    I installed a second server with device audio, with only gateway for skype.
    Now for make the final configuration , what I do?
    Make tunnel between two server and in primary server set as gateway ip other server?
  2. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    Dont waste your time. Use this one at your first server
    [​IMG]
  3. TotallyVoIP
    Jul 2, 2010
    77
    it is simple to have multiple Skype gateways running on 1 server, from separate PC's even over a VPN
    On the skype gateway when you install it just enter the IP address of the 3CX server (not local host, as it is not the same PC).
    On the 3CX trunks you enter the IP address of the PC hosting the Skype gateway.
    We used fixed IP's on our network, so once a MAC address is added it always gets the same IP internally. If you have a different setup you will not be able to use IP's, I have not tried the machine names, this might work too.
    Just remember to use a new gateway port number for each Skype account (increment by 2 is I understand the norm).
    Any problems, post the issue, but it was pretty straightforward.
    good luck
