Use IP in Contact to recognize source equivalent in 5.1?
Discussion in '3CX Phone System - General' started by ITWorks, Mar 6, 2008.
  1. ITWorks
    ITWorks New Member
    Apr 7, 2007
    With 3CX version 3.1 one could select “Use IP in 'Contact' to recognize source”. This would prevent the following error with calls through our Cisco 2811 ISDN PRI gateway.
    [CM010001] Line configuration does not allow identification of the source of this call. Check Advanced Options for Gateways and Providers and match a field to a correct value from the following: Contact IP: ''; From: '9995553327'; To: '5556180'; Rline: '5556180'; Contact: '9995553327'
    I would like to know what the equivalent settings are to do this in version 5.1 as I have the same error but no obvious setting choice in the line settings. Any help would be greatly appreciated.
