Use of the api CallControlAPI
Discussion in '3CX Phone System - General' started by sbsconseil, Sep 5, 2009.
  1. sbsconseil
    Apr 29, 2008
    29
    Somebody in t he(it) to use the api Call Control of 3CX?
    Have you models of use to be shared ?
  2. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    We have developed a couple systems with the API and the HTTP API, But nothing to spectacular.
  3. sbsconseil
    Apr 29, 2008
    29
    hi,
    I would like to make a system of supervision of the Extension and the truck SIP
    I do not know the developpement .NET I want to use the API Call Control with Windev
    Have you a documention or a modele to know how works the API
  4. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    What is the "Windev"?
  5. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,887
    190
    The API is documented on our WIKI and includes samples. A .NET developer should be able to integrate with 3CX pretty rapidly. Developer support packages are available at 1995 euro per year if needed.
  6. sbsconseil
    Apr 29, 2008
    29
    hi,
    WINDEV a powerful IDE & ALM suite, lets you build strategic projects easily and quickly thanks to its total integration, ease-of-use and cutting-edge technology. .Net, Java code and more!
    http://www.windev.com
  7. tpinnovations
    Jul 30, 2009
    296
    Looks very similar to Iron Speed.
  8. SY
    3CX Support
    Jan 26, 2007
    1,825
    So, what is a problem to use it?
  9. sbsconseil
    Apr 29, 2008
    29
    Hello
    I do not know how to use the API via an application
    I need a model to see are functioning
    I want to make a system of supervision of truck sip and the simple Extension for the administrators 3CX
    Simple one web pages or application which groups together(includes) one or some waiter(server) 3CX
    Which type of language use you WFP.NET......
  10. pat71
    Mar 17, 2016
    44
    Any one knows how to change the extension status to busy using using API, that is presence like connected, busy, outforlunch and so on.
    your help is appreciated.
