Use RPID for caller ID information
Discussion in '3CX Phone System - General' started by L2SHO, Jul 29, 2008.
  1. L2SHO
    Jul 29, 2008
    How do I set up my provider setting to use the information in the RPID header for the caller ID name and number on incoming calls? No matter what I set it seems to always use information in the From header, and the RPID doesn't get forwarded on to the endpoint phone either.
    In the Gateway/Provider Inbound Paramaters, there is no field to use the display name part of any header, only the user part.
