Use sip/TCP for Voip Provider
Discussion in '3CX Phone System - General' started by Itzik, Mar 31, 2009.
  1. Itzik
    Mar 30, 2009
    בס"ד
    I what to call to user that reside on OCS 2007 R2 The "Mediation Server" need sip/tcp to pass the call, How can I config the VoIP Provider to use sip/TCP instead sip/UDP?
    note:
    I successes :p to make a call from 3cx to ocs because I notice that the 3cx after some retrying use sip/tcp but it not persistent.
    Thx,
    Itzik
