User Agent List
Discussion in '3CX Phone System - General' started by Vald. Birn, Apr 24, 2014.
  1. Vald. Birn
    Apr 24, 2014
    6
    I am trying to use a small program, called SipCLI on our 3CX PBX.
    I want to send a wav file, to a specific number.
    I just get this error in the Log
    Error Message:
    PBX has dropped a message with 'User-Agent: sipcli/v2.5' from IP X.X.X.X because it is on blocked UAs list
    Is there a way to remove sipcli, as a blocked user agent, on our own PBX?`
    Thank you in advance
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    To remove a UA from blacklisted IP list go to settings--->security---->blocked ips
  3. Vald. Birn
    Apr 24, 2014
    6
    This is only doable in version 12?
  4. jpillow
    Jun 20, 2011
    1,342
    No the blacklisted IP feature isnt specific to v12
  5. Vald. Birn
    Apr 24, 2014
    6
    Well, then i don´t understand the error.
    Because i don´t have any blocked IP´s in there.
    It seems to me that it is the program "SipCLi" that is blocked. Does 3cx have a permitted User Agents list, where this utility might be blocked in?
  6. jpillow
    Jun 20, 2011
    1,342
    It sounds as if 3cx thinks it is being hacked, I've seen a server being hacked and 3cx would block the IP however when you go to the blocked IPs feature that IP isnt listed... Post a log if you can I'd like to see whats there.
  7. Vald. Birn
    Apr 24, 2014
    6
    Well all i get in the log is this:
    30-apr-2014 14:36:47.184 PBX has dropped a message with 'User-Agent: sipcli/v2.5' from IP 10.1.72.154 because it is on blocked UAs list
    Nothing after and nothing before..
    The SipCLi client just times out in the call process..
  8. jpillow
    Jun 20, 2011
    1,342
    I'd open a ticket with 3cx at this point
