User change Voicemail Delivery in Version 12.5?
Discussion in 'Windows' started by swink, Nov 19, 2015.
  1. swink
    Oct 9, 2014
    15
    Can the end user change the option for their voicemail to go to email? If so, I am overlooking it.
    Thanks,
    Michael
  2. CentrexJ
    CentrexJ Member
    May 5, 2009
    443
    73
    You can give them access to the management console just for their own extension and from there they can configure voicemail delivery, call routing, BLFs, etc for their extension only.
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,416
    277
    But you also open up the possibility for them to screw other stuff up...
    This need, as well as the user changing their mobile number, should both be available in the softphone(s) so they do not need to remember yet another login.
    http://www.3cx.com/forums/post174846.html#p174846
