User Contacts as Public Folder Contacts
Discussion in 'CRM / Helpdesk / App Integration' started by Martin_CCN, Nov 10, 2017.
  1. Martin_CCN
    Nov 10, 2017
    Hi all,
    I am wondering if it's possible to use a shared mailbox contact folder as the public Folder for contacts.
    As far as I know, Exchange 2013 and 2016 using normal user accounts in which they create folders.
    So it should be possible to choose the contact folder from a normal user or a shared mailbox too.
    Does anyone know how to set the path to a shared mailbox folder correctly?
    best regards
    Martin
