User Friendliness on VM.
Discussion in '3CX Phone System - General' started by tjabaut, Jan 15, 2008.
  1. tjabaut
    tjabaut New Member
    Jul 24, 2007
    123
    My clients keep complaining about the VM system. Is there a way to have the user prompted or walked through the options at the end of a message?
    For instance; after a message is played we would like it to say, press 1 to replay, press 2 to ... , press 3 to delete , and so on.
