User permissions
Discussion in '3CX Phone System - General' started by jduncan, Sep 6, 2007.
  1. jduncan
    Jul 26, 2007
    31
    Hi all,
    is it possible to create multiple logins with limited or customized access to certain features of the 3cx web interface? I would like to give say the managers access to view full call logs and history and the dashboard overview of all the extensions. I know about the call assistant but i want them to be able to see the call logs mainly but not be able to modify the rest of the system.
    Thanks, JD
  2. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    Hi, this sounds like a good "future feature request" so I am moving this topic to the right forum.
    I will also make sure to forward the request to the appropriate channels.
    Regards
