User Portal (myPhone) Login Error
Discussion in '3CX Phone System - General' started by dab, Jun 30, 2010.
  1. dab
    dab
    Nov 1, 2009
    67
    I'm running V8.0.10824.716
    If I try to login from one extension to the User Portal I get the following error:
    "An exception occurred user_login Error: String was not recognized as a valid DateTime."
    The only thing I know is that a user tried extensively with a wrong password, that's all. Is there a kind of lockout function?
    This only occurs on one extension, I can't find anything in the logs, or I'm searching in the wrong logfiles ...
    I've also tried to restart the services, complete server.
    Can someone direct me to the right path where to search?
  2. diverguru
    Aug 31, 2010
    Did you ever find out what this is?
    Juan
  3. bemar
    Sep 3, 2009
    I have the same Problem with 8.0.11356.754.
    Does anybody know the reason? Must be something with the user record. Some users can login, some are getting this error.
    Ben
