User Web interface
Discussion in '3CX Phone System - General' started by marksgt35, Jun 15, 2014.
  1. marksgt35
    Jun 15, 2014
    7
    So I may be asking a totally idiotic question. I'm a new administrator to 3CX, and although it appears as if there is a user web login to the server, I can't find any documentation on what the URL might be? If there isn't, why do users have a"user password" in the setup?
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    http://xxx.xxx.xxx.xxx:5000/mainform.wgx
  3. marksgt35
    Jun 15, 2014
    7
    And I'm going to assume the user uses their extension as the username and the user password as the password? When I try them, it says username or password incorrect. Is there any other settings needed for them to login?
  4. jpillow
    Jun 20, 2011
    1,342
    What username and password are you referring to? 3cx phone or admin?
  5. marksgt35
    Jun 15, 2014
    7
    Yes, the 3cx phone, that is in the user extension screen.
  6. Shark8000
    Jun 15, 2014
    9
    If you entered the extension options there is an option tab at the end there is a check box "Allow 3CX Management Console Access" along with other options if you check it the user will be able to access the management web interface
