Users Cant Register
Discussion in '3CX Phone System - General' started by ankycooper, Jul 23, 2007.
  1. ankycooper
    Jul 23, 2007
    I have Just installed 3CX Free
    Its a Test Environment (there is no Firewall, Everything is on same subnet)
    I have Created 3 EXT
    Now when i Login Using 3CX Call Assistant
    Its shows all ext in ext Status but at the bottom with ! it says 10002 User not registered
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Do you have any hardware phone or software phone had been setup for register to 3CX box?
  3. ankycooper
    Jul 23, 2007
    Ya i tried software phone
    it shows the list of ext
    but does not get registered
  4. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Have you setup the softphones yet? Until they are registered that would be the correct response from CA.
    Rob
  5. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Re: Ya i tried software phone
    Call assistant is not a software phone, just a look at what extensions are being used, available or off.
  6. nb
    nb Support Team
    Jun 7, 2007
    2,153
    170
    What software phones are you using? Registering an extension is very straightforward - There are mostly 2 main reasons why a simple phone would not register to a 3CX extension: IP addressing/ports and credentials.
