Using 3CX as a default dialer. - Android
Discussion in 'Ideas' started by mortenjorge, Jun 21, 2017.
Using 3CX as a default dialer. - Android 5 5 5votes
5/5, 5 votes
  1. mortenjorge
    Apr 1, 2015
    59
    12
    It would be lovely if you could choose 3CX as your default dialer on your Mobile phone..
    When clicking a phone number, i can choose several other dialers, like skype, Google hangout but 3CX doesnt appear on this list.
    I believe this can be added, just by "telling" Android that 3CX is a phone dialer.
    Several free services on the app store supports taking the dialer role, but i prefer 3cx...
    Thank you!
    patrick.eekhout and jed like this.
  2. uptime1
    uptime1 New Member
    Jan 13, 2012
    112
    30
    +1
    Would be AWESOME!
  3. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    User should be able to select 3CXPhone as default phone app which would also handle (e)SIM-based calls!:cool:
    • InCallService
    Android's enterprise features:
    PROPERTY_ENTERPRISE_CALL
    #3 Sopock, Feb 17, 2018
