Using 3CX as a Fax gateway
Discussion in '3CX Phone System - General' started by ksalter, Sep 24, 2008.
  1. ksalter
    Sep 24, 2008
    7
    The free version does not have fax support, so I was wondering if anyone knows:
    I have some fax machines connected to ATAs that are T.38 compatible. I would like to know if 3cx is capable of sending faxes from these devices out through a PSTN device (specifically I have a Grandstream 4104). Also, I need to be able to receive a fax from the PSTN and relay it to the fax machine.
    Thanks!
  2. Discovery Technology
    Apr 19, 2008
    278
    You might be able to try your fax devices by utilising the 2-user limited license to evaluate the faxing componet of 3CX - possibly worthwhile running past them to prove that your gear works (which it should)
    Cheers, Brendan
  3. ksalter
    Sep 24, 2008
    7
    Sorry all, I have moved on to another solution. I am using an AudioCodes TP1610 cPCI board for my faxes, and it is working quite well.
  4. Discovery Technology
    Apr 19, 2008
    278
    with 3CX?
