Using 3CX with Microsoft Access 2003
Discussion in '3CX Phone System - General' started by gregsonandbrooke, Apr 29, 2010.
  1. gregsonandbrooke
    Apr 29, 2010
    Hi.
    I am in the middle of designing a new database in access 2003. I would like to intigrate into this a softphone. so the soft phone appears just like any other 'form' i create.
    I want to be able to click on numbers in the database and it dials them. i want the dtabase to record the calls and manage the control panel. and be a integral part of the database.
    I cant find anything or any VBA or softphone or template or sample to help me with this. does anyone know of any or any help
  2. strongp
    Sep 4, 2008
    7
    Did you manage to integrate 3cx with your VB code? I'm hoping to do the same thing and would appreciate any pointers...
