using 3cx with Voipswitch
yelgadi
Hi All,
I was wondering whether it would be possible to connect 3cx with voipswitch system,
here is the setup in its basic form:
GoIP Gateway --- 3CX --- VoipSwitch
I managed to connect Goip to 3cx , but for some reason i cant get the connection between 3cx and voipswitch to work,
I am trying to use an extension on 3cx as a sip trunk on voipswitch , i managed to do this between two 3CXs,
any ideas??
Thank you in advance and have a nice day
If Voipswitch will register to a provider (I assume you are trying to register to an extension in 3CX), then why not just use a bridge trunk and Voipswitch can register to that?
See this post on connecting to another PBX.
bridging-3cx-with-an-asterisk-pbx-44726.html
Thanks leejor,
will give it a try :)
Hi again,
I tried as per the instructions but still it wont work, i tried the same with an asterisk system and it managed to connect to 3cx , but for some reason voipswitch doesnt know how to authenticate to 3cx! o_O
17-May-2016 01:16:16.914 [CM102001]: Authentication failed for AuthFail Recv Req INVITE from xxx.xxx.xxx.xxx:443 tid=16162012730650171992433 [email protected]:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP xxx.xxx.xxx.xxx:443;branch=z9hG4bK16162012730650171992433
Max-Forwards: 70
Contact: <sip:xxx.xxx.xxx.xxx:443;transport=udp>
To: <sip:[email protected]:5060>
From: <sip:[email protected]:443>;tag=16162071992308
Call-ID: [email protected]
CSeq: 2 INVITE
Allow: INVITE, ACK, OPTIONS, BYE, CANCEL, REGISTER, INFO, NOTIFY, MESSAGE, SUBSCRIBE, REFER, PUBLISH, UPDATE
Content-Type: application/sdp
Proxy-Authorization: DIGEST username="10000",realm="3CXPhoneSystem",nonce="414d535c0d4ae5c012:6673fa316af27a557743809be02dace4",uri="sip:[email protected]:5060",response="5bc2a88acda073c65c54ba41ed9e3f2c"
User-Agent: VoipSwitch 2.0
Content-Length: 663
Remote-Party-ID: <sip:[email protected]:443>;privacy=off;screen=no
v=0
o=- 424499492 424499493 IN IP4 xxx.xxx.xxx.xxx
s=VoipSIP
c=IN IP4 xxx.xxx.xxx.xxx
t=0 0
m=audio 6816 RTP/AVP 18 0 8 4 3 9 96 97 98 99 100 102 103 101
a=rtpmap:18 G729/8000/1
a=fmtp:18 annexb=no
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:4 G723/8000/1
a=rtpmap:3 GSM/8000
a=rtpmap:9 G722/8000
a=rtpmap:96 AMR/8000
a=fmtp:96 octet-align=1;mode-set=7
a=rtpmap:97 AMR-WB/16000
a=fmtp:97 octet-align=1;mode-set=8
a=rtpmap:98 speex/8000
a=fmtp:98 mode="5"
a=rtpmap:99 speex/16000
a=fmtp:99 mode="5"
a=rtpmap:100 SILK/12000
a=rtpmap:102 SILK/16000
a=rtpmap:103 SILK/24000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
17-May-2016 01:16:16.914 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
Invite-UNK Recv Req INVITE from xxx.xxx.xxx.xxx:443 tid=16162012730650171992433 [email protected]:
Max-Forwards: 70
CSeq: 2 INVITE
Content-Length: 663
Getting Started - Admin
Ramishvohrw
Get 3CX - Absolutely Free!
3CX
