using 3CXphone for iPhone on Interactive Intelligence's CIC
Discussion in 'iOS' started by atsang0303, Aug 22, 2011.
  1. atsang0303
    Aug 22, 2011
    Hey guys!
    Has anyone used "3CXphone for iPhone" on Interactive Intelligence's CIC. I tried the soft[hone on iPhone 4 but failed to register it as a CIC extension.
    Phone Model: iPhone 4
    Generation: 4G
    Firmware Version: 4.2.X
    Jailbreak: YES (Suppose NO for actual use)
    Cydia Installed: Not sure
    Issue Info
    Handset: Phone
    Contacts: Local
    Connection: WiFi
    Server: Internal
  2. willow
    willow Member
    Mar 1, 2011
    471
    Re: using 3CXphone for iPhone on Interactive Intelligence's
    the 3cx for iphone is really only for the 3cx PBX, its not supported on any other platform and thus you probably wont get much help.
  3. StefanW
    Jun 2, 2009
    1,216
    88
    well, we dont test it against any other solution the ours, but will work when the other party uses RFC sip.
